grounding straps?
Old Feb 8, 2006 | 12:46 AM
powered69ing's Avatar
Car: 87 iroc-z z28 camaro
Engine: 5.7 tuned port injection
Transmission: automatic
grounding straps?
where are the grounding straps located on a 87 z28 camaro?
Old Feb 8, 2006 | 12:53 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Back of the passenger side head is the actual ground strap. Then there is the ground strap from the negative battery terminal to the front of the engine block.
Old Feb 8, 2006 | 01:49 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
there should also be one from the battery to the fender.
Old Feb 8, 2006 | 09:06 AM
thanks guys
Old Feb 8, 2006 | 11:15 AM
Car: 86 T/A
Engine: HSR 355
Yep, it tiny so I upgraded mine to 4 gauge wire.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
loud91rs
Oct 5, 2015 10:05 PM
lewandom
Oct 1, 2015 08:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
