Glow gauges and fan switch - problems
Old Feb 15, 2006 | 01:03 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
1) Minor problem here, got the reverse glow gauges, they're selectable, blue or green color. When I have them on blue, I get that interference or whatever it's called sound, like a high pitch quiet buzzer.
When I switch to green, no sound at all.
Is it due to wiring ? How can I fix it ?
I can get it to go away but only by dimming the blue gauges, and I like it turn on all the way.
2) Bigger problem here. I installed the manual fan switch and I wanted to run a blue LED in a holder, hooked up to the switch.
I did a search and wired it according to this post:
https://www.thirdgen.org/techbb2/sho...hreadid=229310
Problem is, it worked the opposite way, i.e. when switch was OFF the light was on, switch was ON light was off.
Additionally, I think I somehow burned \out the LED since after a while I couldn't even get back to the initial reverse order.
Could I do it this way ?
Run a wire from a 12V source, through a resistor, to the LED, and run one wire from the LED to the wire going in to the switch from the fan relay ?
Old Feb 17, 2006 | 01:07 AM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
I have those guages. THey do hum on blue over half power. I think that is a natural side effect of the high voltage involved. THey are too bright over half anyway. Turn your radio louder.
Wire the negative side (short lead, cathode) of the LED to ON switch peg, the one that grounds the fan's relay.
Wire positive positive side (longer side, the anode) of LED to a switched ignition source at fuse box. Put a roughly 680 or so 1/2 watt resistor inline between the positve LED and your switched ignition source, which should be at the fuse box.
Old Feb 17, 2006 | 05:32 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I also have those gauges, and yes mine make the"noise" also. But I cannot turn mine up over half way becuse the are TOO bright. Can't see to drive at night. So I have mine bright enough to see whats going but no noise.
Old Feb 17, 2006 | 03:12 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Alright, thanks guys.
To me they're not too bright, but it may be that my regular dimmer may be off right now.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86IROC112
Aug 17, 2015 02:00 PM
TA8487
Aug 16, 2015 12:21 PM
