Fan Switch LED?
Old Mar 15, 2004 | 06:17 PM
Ville H. Valo's Avatar
Car: 1992 Camaro Z28
Engine: 5.0 Liter (305)
Fan Switch LED?
Here is the delema, i need to know how to wire an LED switch into my fan relay for manual turn on, i want to do it for each switch. thanks
Old Mar 15, 2004 | 10:06 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
i would also like to know how to do this. i am probably going to be wiring my switch into the ecm harness and i want an led so i don't forget to turn my fans off.
Old Mar 16, 2004 | 10:55 AM
rad
Old Apr 9, 2005 | 09:18 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
If you still exist on TGO do you want to know. I have pics of mine that i just finished.
Old Apr 10, 2005 | 10:24 AM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
i'm doing the same thing so post it up!
Old Apr 10, 2005 | 11:34 AM
White91GTA's Avatar
Engine: 5.7L TPI
I got my switch in, but I would still be interested in the pics.
Old Apr 10, 2005 | 04:32 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
Thats fine. For the info part. The parts are only temporarly b/c i realy didnt know what i was doing but i knew what i wanted. I going to remove it and do a cleaner install but this is what i used temporarly.
-1 Medium size green LED (green b/c dash lights are orange)
-(3) 10k ohm resistors-paralled (only ones i had around)
-22awg wire
I grounded the (-)"short side" of the LED to my radio ground and connected the (+) "long side" of the LED to the switch leg of my fan switch. I put the (3) resistors inbetween the radio ground and the (-) side of the LED.
Ill post pics as soon as i get back to my car.
Old Apr 10, 2005 | 04:49 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
You can use a single 1K5 to 4K7 resistor depending on what color LED you use. 5mm is the "standard" size LED.
Old Apr 10, 2005 | 08:41 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
Thanks for the info Josh.
Old Apr 13, 2005 | 07:34 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
Finally got some pics. Please excuse the mess. Im in the process of making a blank plate to cover the radio hole. Im going to put my switches there. Im also going to install my rs232 connectors to the plate for my laptop so i can have a mess free dataloggin'.
I guess my car had a dummy alarm at some point because where the green led is it used to be a red on. I pulled it and installed the green one b/c the gauges are kinda red and i want the led to catch my eye so i will quit leaving my fan on.
The rear defroster switch (dont work) just above the led is my fan switch. Im going to move it to the cover plate once i get it installed.
Old Apr 13, 2005 | 07:37 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
Heres the pics.
Firebirdjosh.
1K5 to 4K7
Whats the numbers on end after the "K"? Tolerance?
Old Apr 13, 2005 | 07:57 PM
Car: 86 T/A
Engine: HSR 355
Sorry for not explaining.
1.5K is the same as 1K5. However on schematics, after being photocopied, etc, the decimal may be overlooked and appear as 15K, so some people put the K in place of the decimal. Both methods are commonly used.
Old Apr 13, 2005 | 08:17 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
Gotcha. Thanks
Old Apr 17, 2005 | 06:55 AM
IroczInOz's Avatar
Seems like you guys have this sorted. I connected 12V (resitor in place) to one side of the LED, and the other side to the GROUND wire of my manual fan switch which is also spliced into the ECM fan control wire.
This way the LED will light up when the ECM turns it on, or when you turn it ON.
Old Dec 1, 2005 | 08:06 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Could one mofidy this or use it so one can use a manual fan switch that already has a LED built into it ? i.e. one of those switches that have a light in it
Old Dec 2, 2005 | 12:04 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
yes. just find out what connectors are what on the back of the switch.
Old Dec 2, 2005 | 01:29 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
hmmm so I would tap into green/white wire on the relay and connect it to the switch ... run one wire from switch to ground.. and one wire from switch to a power source ?
Would this work as true on/off with light .. i.e. fan on - light on .... fan off - light off ... ?
Old Dec 2, 2005 | 05:35 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
As far as what color from the relay i dont b/c mine is straight wired and i dont rely on the ecm.
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
85Special
DIY PROM
Sep 3, 2015 04:21 PM
