unplugging the engine harness
Car: 87 Trans Am
Engine: now a 350
I want to unplug the engine wiring harness. This is the harness that goes through the firewall by the brake booster. how do I do that without breaking anything. (87 Trans Am)
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
That would be the 'bulkhead' connector.
There is a 7(ish)mm bolt, in between the two harness plugs, holding together. Remove it (the 7mm bolt) and you can unplug it (the bulkhead connector).
eightsixseven
Dec 16, 2024 01:50 PM
Sanjay
Aug 12, 2015 03:41 PM
