fuel pump relay question
Old Mar 1, 2006 | 07:57 PM
bigbird89's Avatar
Car: 86 Firebird
I am trying to diagnose my 90 f-bird's problem. I have so far narrowed it down to the relay. There is no clicking noise from the relay, even after I replaced it. I have searched the boards, bu I'm still not sure which wire send power to the relay. If the relay is not working, the fuel pump won't come on at all, right? I've checked all of the fuses and so far I am lost. Any help would be MUCH appreciated.
Also, could my ECM be fried, and how can I tell?
Old Mar 2, 2006 | 09:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you checked the 20 AMP fuse located near the battery?
Old Mar 5, 2006 | 10:10 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
LET's BE FUELISH
Originally posted by bigbird89 ............narrowed it down to the
relay..............not sure which wire sends power to the relay..............checked all of
the fuses..............could my ECM be fried..............?
<B><CENTER>
If your ECM is defective or has a
bad connection your relay
will not function. Connect a voltmeter
to pin A1 at the ECM. Then turn ignition
to the run position. You will see a
voltage on A1 for two seconds if the
circuit is good up to that point.
</B>
<P>
<TABLE BORDER=9 CELLPADDING=18
<TD BGCOLOR=black WIDTH=60><B><H3><CENTER>REFUSE
.TO
.LOSE</TABLE></CENTER>
Old Mar 5, 2006 | 06:22 PM
bigbird89's Avatar
Car: 86 Firebird
The fuse was fried, I replaced it first, then the relay. What makes me think it may be the ECM is that the oil pressure switch should still tur on the pump after cranking for a few seconds. Since the switch is wired in parallel to the relay, maybe its not getting power from the ECM. I will check A1 with a voltmeter tomorrow.
Where's A1?
I'll do a search.
Old Mar 5, 2006 | 10:18 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
On your vehicle it wouldn't do you any good to check voltage at pin "A1" of the ECM unless you have a 305 TBI. That would be the fuel pump relay driver for that vehicle and would be the green/white white wire going to pin "C" of the fuel pump relay. On the 3.1L, 5.0L & 5.7L TPI models it would be the wire going to pin "A11" of the ECM. It would be easier to check for voltage at pin "C" of the fuel pump relay than digging into the ECM wire harness. Another question here, have you by any chance checked the ground wire at the back of the cylinder heads?
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
