finding vss wire?
Old Mar 5, 2006 | 11:17 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
Transmission: 5 speed
finding vss wire?
Hi, I just installed a 4th gen delco radio with scv, I need to find the vss wire by the ECM in order to make the scv to work, did a seach and could not find the wiring for my year, 84z28 305(vinG) 5speed. any help would be appreciated, thank you.
Old Mar 20, 2006 | 04:46 AM
Firebat's Avatar
Your speedo is mechanical. However, i think there is a vss box or something at the speedo you can tap into. Hopefully someone with more knowledge on mech speedos will chime in...
Old Mar 21, 2006 | 05:29 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
you can tap into the wire at the ecm just get a wiring diagram of the ecm to find out what wire it is
Old Mar 21, 2006 | 09:36 PM
Jza's Avatar
Jza
Near your ECM is a clear connector call the I/P (instrument panel) connector. There should be three branches in the harness, two go to the ECM and the other is the IP connector.
Unplug that connector.
If you look at the end of the connector you can see that one row is shorter (has fewer pins) than the other. On the shorter row: the second wire from one end (it should be the only dark brown wire in that set) is the speed signal. You should be able to tap off of that.
Oh, yeah, almost forgot: Plug the connector back in
Old Mar 22, 2006 | 07:53 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
And if that works let us know, here and in your other post in the audio forum.
Old Mar 22, 2006 | 11:28 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
Hey Jza, thanks for that info, are you talking about this group of wires that are not directly plug into the ECM, but attach to the side of it? there is one brown wire (see pic), i will give it a try this weekend and let you know how that turn out. thanks so very much.
Old Mar 22, 2006 | 11:34 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
sorry, here's the picture
sorry, I can't seem to attach the picture with this new fomat.
Old Mar 22, 2006 | 11:57 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
sorry, here is the picture again
Old Mar 22, 2006 | 11:58 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
and here is another view
Old Mar 23, 2006 | 08:29 PM
Jza's Avatar
Jza
Yeah, that's the connector, but the brown wire looks like it's the one on the end?
Dunno, but for an '84 it should be brown, and all the diagrams I checked show brown for that circuit. I don't think they switched to gray until '90 or '91.
Old Mar 24, 2006 | 02:43 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
Hey Jza, thanks, I will tap into the shorter end(bottom end) with the clear plastic side of brown wire and let you know how that work. thank you very much.
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
apie2546
Aug 8, 2015 07:12 AM
