speedometer not working after engine swap
Old Mar 13, 2006 | 09:18 AM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
I pulled the 305 engine out of my 87 Trans Am and put in a 350. The car was carbed and I replaced it with a non computerized carb. I took out the ecm since the engine doesn't need it. Does the ecm run the speedometer? I can't figure out why the speedometer doesn't work.
Thanks,
Matt
Old Mar 13, 2006 | 11:02 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You may have inadvertantly pulled the VSS buffer box (little yellow box under the pass side dash) as well.
Old Mar 13, 2006 | 11:44 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
I did plug the little yellow box back in but the speedometer still doesn't work. I'd do some research but the search function is down. AARRGG!!
Old Mar 14, 2006 | 09:38 AM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
Was there anything else that needs to be plugged in in the area of the VSS buffer box, because there are a lot of empty plugs there.
Old Mar 14, 2006 | 05:03 PM
deadbird's Avatar
Engine: TPI 305/ v6
The buffer box shoulld be able to work by it's lonesome.
It obviously needs power and the input from the VSS on the trans.
Buffer box should look like sew..
Old Mar 20, 2006 | 09:11 AM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
I see that it has two plugs going to it. I think I have one thing plugged in. Thanks for your help.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
marcusaw
Aug 10, 2015 08:13 AM
