From tpi to carb helppppppppp
Old Mar 20, 2006 | 04:57 PM
RandyZ's Avatar
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
i ditched the TPi system now i have ? has anyone else done this i took the wiring out but some was hooked in to the reg wiring harness is this posible ? and if so was it ok to cut it ?
Old Mar 21, 2006 | 02:58 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
Scary isn't it?I did the same thing on my car, except i went from 2.8 multi port to a 350 carb.I found that the two harnesses really only share a couple of common grounding points at the back of the motor.I unplugged the ecm from under the pass.side dash and fed the harness through the fender and into the engine compartment on the passenger side.My car had a mess of relays over the brake booster,i unhooked them and fed the harness they were connected to around the back of the block.This is where it is hooked in to the grounds at the back of the motor.Make sure you leave the grounds for the main harness.Next,i went to the power junction block beside the battery on the passenger side and unhooked everything,leaving the alternator wire and the one from the battery.you'll also have to take the fuseable links on the passenger side inner fender.If you run a electric fan or fans,you will want to re-use one of the fuseable links and the relay over the junction block to re-wire it up.I wired my fan relay to a toggle switch for now but plan to use a thermal switch when i get to it .It helps to take some of the loom off so you can see the wires.I think the alternator plug/wires run through this loom for a ways,pull it out and re-route them.At this point,the harness came out in one big piece.Now i have to say that my car was badly hacked up by a previous owner,and the wireing was already compromised,the car already had mechanical gauges for oil and temp,so i'm not sure about these wires,but this should give you enough of a idea to get you started.I used a test light alot to make sure some wires were dead with the key on and off.Your car might not be wired like mine,but some of it should be simular enough for this to be of some help.I know this sure cleaned up my engine bay and got rid of about 10 pounds of junk that was dead weight anyway.Hope this helps alittle.I should also mention that if you have an automatic trans,it won't lock up the converter without the computer,there are kits available to run 700r4's without a computer.You gotta run a non-computer HEI distributor also without the computer.
Old Apr 2, 2006 | 12:26 PM
zrated57's Avatar
Which distributor would you recommend using on a carbed engine that has the TPI system and ECU removed? How would it be hooked up if the ECU is gone also? thanks
Old Apr 2, 2006 | 02:43 PM
LT1ROC's Avatar
You will need to use a standard vacuum advance HEI distributor...you will not be able to use the large or small cap HEI computer controlled distributor any longer.......
Old Apr 4, 2006 | 09:22 PM
project86ta's Avatar
Car: 86 TA
Engine: 305 carb
Transmission: 700 R4
Axle/Gears: Not Sure
msd-8365 should work
Old Apr 6, 2006 | 10:53 AM
zrated57's Avatar
I have a MSD 6A spark module box that's hooked up with my current TPI distributor and I was wondering if I could still use that MSD when I ditch my ECU and FI?
Old Apr 6, 2006 | 10:42 PM
LT1ROC's Avatar
The box itself can be used with the vacuum advance HEI you'll be using....not plug and play like with the TPI....u will hard wire it into the distributor ditching the module and condenser.....go to MSD's website to get the diagram you need.....piece 'o cake
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
