Aux Fuse Panel 87 Iroc
Old Mar 22, 2006 | 03:53 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Thinking about installing an auxiliary fuse panel in the car
for key on acessories.
Adding heated oxy sensor, N20 wiring,gauge pod wiring
ect. ect. Don't want to tap into and splice all over the place
and keep it neat Looked at a couple Aux panels from
Summit from 3 to 7 slots and relays.
Just wondering where the best place would be to bring the
key on power would be, to the panel
There showing a 30 Amp power in main and 20amp slots
for the acsessory plug in's.
Any electrical advice on this appreciated
Later
Old Mar 22, 2006 | 11:58 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Why not use the same key on wire the origional fuse box uses? I'm pretty sure it can handle 2 tasks.
Old Mar 23, 2006 | 01:26 PM
jaykar's Avatar
Fuse Panel
Hi,
Thats probably what I'll do.
May have to fuse up that circuit if it is fused in the main
fuse panel with the added panel
Not sure about what I just stated, but sounds logical
Once I pull the original panel all will be clear
Later
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Street Lethal
Aug 14, 2015 08:25 PM
mustangman65_79
Aug 11, 2015 03:17 PM
