no speedo or gas gauge
Old Mar 22, 2006 | 09:17 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
My car is a 91 RS and it has a ZZ4 crate swapped into it and no computer any more how can i get my speedo and gas gauge to work now? does anyone have a wiring diagram to help me out with the routing of all the wiring in these two circuits?
Old Mar 22, 2006 | 11:48 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
http://autozone.com/images/cds/gif/l...3d80163fea.gif
Old Mar 23, 2006 | 12:17 AM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
i dont see anything about the speedo or gas gauge in there and also i have no ecm so i need to know how to wire it the oldschool way
Old Mar 23, 2006 | 12:27 AM
Dirtbik3r's Avatar
I could be wrong, but I think the guage is wired in series with the fuel pump circuit.
Old Mar 23, 2006 | 01:28 AM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
if it is in that diagram i dont know how to read it and all that stuff runs off the ecm in the middle that is an ecm diagram
Old Mar 23, 2006 | 10:18 AM
Dirtbik3r's Avatar
Nope, that is an engine electrical diagram. That's what your wires looked like before the zz4 deal. I'm gonna check my chiltons after i eat. I've seen the fuel level sender unit in there.
Old Mar 23, 2006 | 11:53 AM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
by the way thats a hot car
kinda reminds me of mine...
Old Mar 23, 2006 | 12:52 PM
Dirtbik3r's Avatar
Ok, i lied. I believe it's on its own circuit. Looking at the diagram, 2 wires lead to the tank for the fuel gage. One being pink, the other black. Both go through a connector named C313. From there, the black goes through ground distribution spot G304. The pink leads to the fuel gage in the instrument cluster. Coming out of the fuel gage, is a pink/black wire (C1 on instrument connector) which leads to the fuse block (10A fuse).
Hope this helps.
Old Mar 23, 2006 | 12:53 PM
Dirtbik3r's Avatar
Hope this helps.
Old Mar 23, 2006 | 02:23 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
yes it does thank you now i noticed that my speedo works when the headlights are off but not when they are on and the dash lights on the speedo and gas gauge dont work when the headlights are on but light up dim when they are off but the rest of the gauge lights work normal
does this seem like a ground issue?
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
BurlyChev
Aug 16, 2015 09:08 PM
