left headlight not popping up
Old Mar 20, 2006 | 11:04 PM
BanditMan's Avatar
Car: 84 trans am
Engine: 305 H.O. with small cam
Transmission: th350 with manual valvebody
Axle/Gears: 3:73's
Ive had my TA for about 6 months now, mostly of which its been grounded cuz of a damned 700r4. But im about to get it going again and the left headlight right headlight dosent come up. The light gets power. The motor dosent spin at all, so yall think its just worn out springs and brushes, or a bad relay? Id hate to know its a bad motor, cz those suckers are expensive, even at a junkyard i was quoted 55 bucks. Just throw me some opinions guys
Old Mar 21, 2006 | 07:36 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Check to see if you're getting power to the motor with the headlight switch on. If you are it's probably the brushes inside the motor - probably $1 or $2 at a JY for the whole switch. If no power it's probably the actuator relay or a broken wire.
Old Mar 21, 2006 | 12:40 PM
BanditMan's Avatar
Car: 84 trans am
Axle/Gears: 3:73's
I dont believe its the switch itself, b/c both headlights light up, just the left one dosent popup. Ill get out there some time and use my brothers fluke meter on the wires for the motor and see if its gettin juice. Ill trace that sucker down, lol.Isnt there are diagrahm in the chilton manual, cuz thats what i have, or do you know where all of the relays are.Thanks man.
Old Mar 21, 2006 | 01:11 PM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
When I said the "switch" I meant the one that's inside of the cover on the motor - the one that holds the brushes. On my '84 the headlight actuator relays are mounted on the fender well (though I have seen them mounted on the motor itself). Just follow the wires back from the motor to the relay. The "isolation" or master relay is mounted on a bracket near the radiator on the passenger side.
Old Mar 23, 2006 | 11:55 PM
BanditMan's Avatar
Car: 84 trans am
Axle/Gears: 3:73's
aight man, thanks.
gta892000
Sep 16, 2015 12:37 AM
Isaac McCormick
Sep 12, 2015 10:20 PM
Randomtask2
Sep 10, 2015 08:37 AM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
