WHERE DOES THIS WIRE GO
Old Apr 4, 2006 | 10:52 AM
pyro719juggalo's Avatar
Car: 1989 RS
Transmission: t5
Axle/Gears: 373 locker
On my alternater I have a plug with a black and a red wire, where does the black one go?
Old Apr 4, 2006 | 11:20 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
There should be a stud with a nut on the back of the alt.
Old Apr 4, 2006 | 11:37 AM
Car: 1989 RS
Transmission: t5
re
I know the stud goes to the battery but where does the black wire go coming out of the plug? it appears to go trough the fire wall
Old Apr 4, 2006 | 04:45 PM
teapot3208's Avatar
Car: 1985 Camaro
Engine: 350 .030 over (355)
Transmission: 700-R4
It goes to an idiot-light or volt guage, I think I've heard it has something to do with charging, but I'm not sure what.
Old Apr 4, 2006 | 05:15 PM
Car: 1989 RS
Transmission: t5
Well my volt meter works but The alternater still wont charge. I hooked a wire from the black wire coming out of the alternater plug to the battery and now it charges. I cant figure out why it wont charge with out this wire?
Old Apr 5, 2006 | 02:13 PM
Ratchet's Avatar
3 wire alternators are wired as follows.
the stud on the back of the alternator has a large wire from the positve side of the battery attached to it. This connection usually comes from the positive terminal on the starter. (the original wiring has a fusable link in this circuit. If you run the large wire from the battery directly or from the terminal block on the side of the Rad cradle make sure it has a fusable link in it.)
The Wire attached to the #2 terminal goes to the stud on the back of the alternator this is the exciter wire, tells the alternator when to charge.
The wire attached to the #1 terminal goes to the gage or light on the dash which ever you have.
Ric
Old Apr 5, 2006 | 03:05 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It should be dark brown and goes to the c/h fan 20A fuse.
The fuse is hot only in run and sends switched power to the regulator.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
