alarm system install&power door locks.
Old Apr 13, 2006 | 04:02 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Hi all,I'm installing a alarm system in my 85 Z28,and i'm not sure where to run the lock&unlock wires from the alarm unit to.From the door lock wiring diagram,it looks like one wire goes to each door lock switch,is this correct or do they have to go to the door lock relays.Any help welcome,i did a search&found info,but not what i need.Thanks.
Old Apr 13, 2006 | 08:25 AM
serpentineocean's Avatar
Car: 1986 Vert Z28
Engine: SuperCharged 350
Transmission: 5 Speed Manual
i might be wrong on this, but i'm pretty sure they run to relays that are located in the driver side kicker panel. (but that might be for the power windows....?)
Old Apr 14, 2006 | 11:50 AM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Serpintine is right there are relays in the driver side kick panel for the door locks they are metal and that is how they are grounded so dont leave them loose. That is how I hooked my keyless entry up. I forget what color the wires are I tapped into. Hope this helps If you cant find it I will try to post pics for you.
Old Apr 15, 2006 | 04:32 AM
alicat's Avatar
Axle/Gears: Stock.
Hi,thanks for the replies,some photos would be great if you have time.
PS,either photos or just which wires you connected to.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
