Temperature sensor hook up
Old Apr 21, 2006 | 08:06 AM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
the temp sensor in the head of my block on the drivers side i lost the white connector to it.
so you think it would be ok if i just soder'd the wire on there?
thanks.
Old Apr 21, 2006 | 07:01 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
you could do that, but why not go to the junk yard and cut off what you need. also, you might be able to buy a new aftermarket connector from some place like napa or bumper to bumper.
the aftermarket ones use a normal spade terminal instead of the goofy one the factor used/uses, so thats another option.
you could also solder a length of wire onto it and use an insulated male and female spade terminal set, this way you don't have to hunt for a connector and keep the ability to unplug it for whatever reason.
Old Apr 21, 2006 | 07:30 PM
Borsty's Avatar
Car: 89 Trans am
hmmm i didnt think of that, cool thanks ill try that.
GTAman
Jul 3, 2024 07:29 PM
gta892000
Aug 11, 2019 11:16 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
FormulasOnly
Sep 10, 2015 09:07 PM
