VSS info needed in SD to MAF conversion
Old Apr 22, 2006 | 09:38 AM
tta1415's Avatar
Car: 1992 Z28
Engine: LC2
Transmission: GM 2004R
I just swapped a complete 89 Turbo TA drivetrain into a 92 Z28
I used the TTA engine harness and plugged it into the Camaro's dashboard wiring at the firewall and under the dash and used the TTA computer.
I have no Oil pressure gauge (I can live with that for now) no Tach (I can live with that too) and no gas gauge but most importantly I'm not getting a VSS signal, the computer throws a code 24 and my TCC won't lockup.
I'm lost.
Does anyone here know where is the VSS wire is on a 89 wiring harness and where is it on a 92 harness?
I'm assuming the differences lie in the standard differences between a SD and a MAF car and the TTA part of the equation isn't an issue.
Old Apr 23, 2006 | 04:13 PM
tta1415's Avatar
Car: 1992 Z28
Engine: LC2
Fixed it:
We added the VSS buffer from the TTA MAF harness to the SD harness at the 207 and C100 bulkhead connectors.
IROCZ1989
Jan 24, 2016 03:55 PM
NBrehm
Aug 25, 2015 11:49 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
