Please ID these (2) wires/ends for me
Old Apr 23, 2006 | 03:58 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I've asked this before (a while back), but recieved very few responses...is there anyone that can postively (to the best of your ability) ID these (2) Plugs for me?...they don't hook up to anything at all, and they look bad...I'd like to remove them...
[IMG][/IMG]
Old Apr 23, 2006 | 10:06 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Here's another Pic
[IMG][/IMG]
Old Apr 26, 2006 | 07:55 PM
Car: 1988 SC Camaro
Engine: 305 TBI
anybody have an idea? someone must have these wires on theire car
Old Apr 27, 2006 | 11:21 AM
Andrew89tpi's Avatar
Car: 91 camaro rs
Engine: 350tpi
I'm pretty sure the one on the left is for the fan for the heater/ac, but if it works then I don't know what it goes to. The one on the right is for the underhood light. HTH
Old Apr 27, 2006 | 01:13 PM
88TTFB's Avatar
Car: 88 TA
Engine: 5.7 TPI
Wires
The grey 1 is the ignition to the external coil for the distributor. There is a black side that goes from the coil the NON HEI distributor. If its not that it may be the pressure switch on the evaporator part of the A/C
Old Apr 30, 2006 | 01:41 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Thats a good guess, but unfortunately they were unplugged even when my old AC Box was in....doesn't make any sence...any more thought?
Old Apr 30, 2006 | 03:51 PM
Car: 91 camaro rs
Engine: 350tpi
I'm digging through the wires on my car and the plug that I said was for the ac stuff is what it is. I don't know exactly what it does. The other connector that has a red wire on it goes to the hood light for sure. I'll look a little more into it to see exactly what the other connector is wired to, but you can bet it's going to be ac/heater related. HTH
Old Apr 30, 2006 | 07:49 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Thanks, let me know if you find out anything else
Old May 1, 2006 | 03:46 PM
Car: 91 camaro rs
Engine: 350tpi
The rectangular connector it has letters on it.
A is a blue wire that goes to the low pressure switch for the AC
B is not used
C is green and it goes to the switch on the controls for the AC
D is a black ground wire
The other connector goes to the high speed relay for the fan I think it supplies the power to it. I have a question for you, does your AC/heater work?
Old May 2, 2006 | 12:40 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
the grey one with the single red wire I thought was for the fuel pump test lead. Put power to it and the fuel pump should run? I might be wrong.
Old May 3, 2006 | 04:12 PM
Car: 1988 SC Camaro
Engine: 305 TBI
well, my fuel pump works fine, and my Heater box is not working right now because its just not hooked up yet (its a non-AC Heater box), i ripped out the old one the was a AC ans Heat (but it was not stock)...those (2) wires ends were loose like that even when the old box was in, and everything worked...the more i think about it, I'm guessing that those wires were meant for the Original AC/Heater box that wasn't in the car when i got it...does that sound likely?
Old May 3, 2006 | 06:46 PM
Car: 91 camaro rs
Engine: 350tpi
The people that had your car before probably took out the other half of the wiring so you shouldn't have to worry about it since your ac/heater was working. You can probably remove the wires if you want, but I would be careful not to create new problems for yourself.
