Hard installing light's?
Old Apr 26, 2006 | 08:08 AM
19kilo's Avatar
Car: 1985 Z-28 2003 chevy Silverado Z71
Engine: was 305 LG4 now 355 HO
Transmission: TH700r4
Axle/Gears: posi 373
Just bought two new turning lights for my 1985 Z-28 how hard is the install of them thing's?
Old Apr 26, 2006 | 11:43 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You're talking about the ones in the fenders? Are you replacing just the bulbs or the entire lense? The light bulb holder is held in place with a bayonet connector. On Camaro you can access it from above. Lift the hood. You can see the passenger side behind the battery, the drivers side is between the horns. Just rotate it 90 degrees CCW and it will come out. Replace the bulb and it rotate it CW. If you need to replace the entire lens, they are held in place with two formed wire retainers. Flip the lever of the retainer and it will loosen it and allow it to slip free of the two tabs that is it in. Then pull out your light. On Camaro you can get to it from below the car.
The front turn signal lenses are held in place with long screws. Remove them from under the car.
Lon
Old Apr 26, 2006 | 11:57 AM
19kilo's Avatar
I am talking about removeing the hole lenss yes the one's in the fender
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
fonzie85
Aug 13, 2015 11:50 AM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
