wont start
Old Apr 27, 2006 | 03:49 AM
30589RS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Axle/Gears: ?
wont start
I have a 89 RS camaro 305 TBI that I stored for the winter. I did all the winterizing that should be done and the other day I tried to start it and nothing happened. Not even a click. All electrical componants work except for the starter. the battery seems fine. The motor would not even turn over? Should I install a new starter and call it a day or what do you think? I need to get my car back home asap. What should I be looking for? I would hate to call a garage and have them take care of some thing minor I could have done my self.
Old Apr 28, 2006 | 12:47 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Whats your battery voltage? Your battery is probably dead from the winter.
Old Apr 29, 2006 | 09:22 AM
30589RS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Axle/Gears: ?
No, The voltage is fine, I thought the same thing at first so I tried to give it a jump and still nothing. Any other Ideas? I will be going to Have anothor look at it next week wednesday or thursday and any suggestions would help.
Old May 3, 2006 | 03:41 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Is it VATS equipped? What you describe is consistent with that system failing. PM me & I'll be happy to relate my VATS experience, and solution.
Good luck,
kk
Old May 6, 2006 | 09:14 AM
30589RS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Axle/Gears: ?
I got it started. The starter was just "stuck". I tapped it a couple times and it fired right up. I started a couple times after that and no problems. I will probably be replacing the starter anyway. Thanks for your responses.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
