Digital Dash
Old May 1, 2006 | 01:12 PM
youngmiguel's Avatar
Car: Trans Am
Engine: 305 TBI
Digital Dash
my speedometer on my dash just reads zero when i drive, and its still in kilometers. but when i knock on it it starts to show the numbers and then goes back to zero. everything else on the dash works. what may be wrong and can i fix this problem myself?
Old May 1, 2006 | 01:28 PM
AussieGTA's Avatar
Car: Trans Am GTA
Engine: 350TPI
Transmission: T700R4
Axle/Gears: 3.45
The read out plugs into the cct card inside the dash at the top of the display. It maybe worth your while to pull the cluster out and make sure the dispay is plugged in properly. The fact that you can get it to display by tapping it tells me you have a loose / broken connection somewhere.
Old May 4, 2006 | 08:45 AM
phoxetis's Avatar
Car: T/A
Engine: 5.0 v8 TPI
it might be somewhat corroded or something. As far as I know you can switch from miles to kilometers using the lower button next to the odo/trip display.
if you re-connect the display plug a couple of times, the dust might be scraped off. Just like Aussie says.
Old Apr 8, 2007 | 11:44 AM
roadking555's Avatar
Re: Digital Dash
this is excatly what my car is doing, cleaning the plug work for you?
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
