Dash Wiring 87 Trans Am
Old May 2, 2006 | 01:08 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
can anyone help me out, i would like to get a wiring diagram for my 86 trans am so i can splice the wires for the 4th gen dash. The topic says 87 but im sure i put 86, guess not.
it was originally 5.0/manual now its 5.7/auto. i purchased the vehicle the owner already changed the motor from the original 305, how can i find out if the vehicle was originally carbureted or fuel injected, im assuming you would need to know this so i can tell what kind of wiring i have in my car?
please help,
Rough
Old May 3, 2006 | 10:56 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
TTT
Old May 5, 2006 | 02:36 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
seriously, someone must have wiring diagrams for an 86 trans am, or know if other years are same wiring.
noone did 4th gen dash swap into a thirdgen firebird?
Old Jun 5, 2006 | 06:29 PM
Firebat's Avatar
here's what i got on my 86 T/A.
Connector 2(top connector)
1- Hand Brake Indicator
2- Ground
3- Illumination
4- Not Used
5- Not Used
6- Not Used
7- Left blinker
8- Brights
9- Right Blinker
10- Fuel Level
11- Not Used
12- Not Used
13- Service Engine Soon light
14- Skip Shift indicator
Connector 1(bottom)
1- Tach-------------------White
2- Ground-----------------Black
3- Illumination-------------Gray
4- Choke indicator---------Blue
5- Water temp------------Green
6- Not Used
7- Not Used
8- Oil pressure------------Tan
9- Power-----------------Pink/Black
10-Not Used
11-Not Used
12-Ground----------------Black
13- Seatbelt--------------Yellow
14- Speedometer----------Green/Black
Hope its all correct!
Old Jun 5, 2006 | 07:15 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
you are the man, thanks alot.
not to be a bother, but what about lights?
Old Jun 5, 2006 | 09:55 PM
Firebat's Avatar
i dont know yet, just started doing the dash swap. Check out shbox.com for 4th gen stuff and the thirdgen.org tech articles. The thirdgen.org tech articles has wiring diagrams for an 86 camaro i think.
Old Jun 7, 2006 | 12:30 AM
Firebat's Avatar
wow. I really had a hard time finding stuff for the 3rd gen trans am to 4th gen trans am dash swap for the headlights/foglights wiring. A lot of BS and less tech there was on this. Here's what i ended up with on the 86:
Headlight/Parklight Switch
3rd gen trans am(86) to 4th gen trans am
RED-----------------------------------------RED
ORANGE-------------------------------------ORANGE
YELLOW(X2)---------------------------------YELLOW
BROWN--------------------------------------BROWN
GRAY----------------------------------------GRAY
BLACK---------------------------------------BLACK
WHITE---------------------------------------(have to put in wire...see note)
NOTE 1: The white wire's purpose is too have 12Volts when the headlights and parklights are turned off to drop the headlight motors. This doesn't exist in the 4th gen harness but you can add the wire. I'm trying to find a prong from another connector thats similar and stick the prong into the right slot. If you look at the 4th gen headlight connector like this:
_______________
|____|-----|____|
place the prong in the slot that is on the bottom, 2 from the right.
NOTE 2: You get the gray and black wire not from the 3rd gen headlight switch but from the connector that has the lightbulb that lights up your thirdgen headlight and dimmer switches.
DIMMER SWITCH
GREEN------BROWN
WHITE------GRAY
BROWN------GREEN/WHITE
BLACK-------BLACK
FOG LIGHT SWITCH
BLACK-----------BLACK
BROWN----------BROWN
BROWN/WHITE---YELLOW
PURPLE----------PURPLE
GRAY------------GRAY
Old Jun 7, 2006 | 11:43 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
wow this helps alot, i plan on picking up the dash this weekend actually and start the day i get it. thanks so much for all the help i will keep you updated.
Old Jun 7, 2006 | 01:13 PM
Firebat's Avatar
The gray colored relays have the same prongs in the connector as the headlight switch connector does. I snagged one prong & wire from the 4th gen hatch release relay since I won't use that relay anyway.
Old Jun 7, 2006 | 01:16 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
Here are some diagrams themselves, hope this helps a bit more:
Old Jun 7, 2006 | 01:19 PM
If you want more give me specific diagrams you need, there are a TON of them and I can't post them all. And give me details as to the options the car has, like head light monitors and such, so I can get the right diagrams.
Old Jun 7, 2006 | 01:26 PM
Firebat's Avatar
I might need some wiring diagrams for the heater controls. I dont know yet.
Old Jun 7, 2006 | 01:39 PM
Let me know, just give me the year, make, model, engine size and sub modela and I will see what I can get.
Old Jun 7, 2006 | 03:58 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i thank you also 91camaro couldnt seem to get any help with this on this board, and most people talked about a camaro not a firebird.
as for details, my vehicle is 86 stock carbureted so no computer, power windows, manual door locks. just the basics head lights, fog lights, power trunk, rear defrost...
Old Jun 7, 2006 | 04:00 PM
Firebat's Avatar
actually the 86 carb t/a does have a computer(ecm).
Old Jun 7, 2006 | 04:12 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
you know what i mean!...i know about the little one on the passenger side..
Old Jun 9, 2006 | 12:53 PM
Firebat's Avatar
FYI...There were a few errors in my previous posts and I fixed them. And still haven't fully tested everything. All the gauges work and headlights/parklights but i haven't tried foglights because I dont have foglights right now.
This is how you get the dimmer to work if it doesn't work: https://www.thirdgen.org/forums/body...4th+gen+dimmer
Old Jul 11, 2006 | 11:54 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
A4 - Dark Grey
A12 - Brown x 2
I have these wires left over on my 3rd gen BLACK connector, did anyone use these???
Old Jul 11, 2006 | 11:56 AM
Firebat's Avatar
You'll have wires leftover
Old Jul 11, 2006 | 01:57 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
did you have these "certain" wires left over? on the chart above it says they are not used, but why are they there?
dark grey to me means illumination but i wonder what for
also red wire on 4th gen plug, general output, just needs to be grounded right?
Old Jul 14, 2006 | 07:11 PM
Firebat's Avatar
I think the red wire goes to power. The unused thirdgen wires are extra grounds, skip shift or don't know what they are.
Old Jul 14, 2006 | 07:27 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
red goes to power, yeah alright...
is it ok to splice more then 1 wire into power?
Old Jul 14, 2006 | 08:59 PM
Firebat's Avatar
Try running your 4th gen gauge without the red wire. I can't remember for sure now if I used it for sure. If your battery gauge doesn't work then connect up that red wire.
I think you might have to splice in more than one wire for power.
Old Jul 14, 2006 | 09:43 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
well i did that already. I have 4 power on my 4th gen, but only 2 on my 3rd gen. So i spliced 2 into 1 and 2 into the other one. I was wondering if there would be an overload with 3 power wires going into 1.
Old Jul 14, 2006 | 09:48 PM
Firebat's Avatar
no, there wouldn't be
Old Jan 19, 2014 | 09:39 PM
solwd's Avatar
Re: Dash Wiring 87 Trans Am
Can you post wiring diagrams fo 1986 Trans Am's dash lights to the headlight with motors? My parking lights will not come on unless headlights are on. Thanks for any help. It would be great to know what relay went to what part.
Old Jul 27, 2019 | 08:10 AM
Jasonpt's Avatar
Hey man I need instrument cluster diagram for my 87 trans Am
eightsixseven
Dec 16, 2024 01:50 PM
Jorlain
Aug 24, 2022 05:11 PM
The_Phoenix
Feb 4, 2016 07:10 AM
stalkier
Aug 13, 2015 12:59 PM
marcusaw
Aug 10, 2015 08:13 AM
