computer compatability
Old May 7, 2006 | 06:43 PM
berlincam86's Avatar
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
I have a computer from a 86 monte carlo (it was writtin in black marker on the computer)#1227169 in my 86 camaro is this going to be a problem? The car won't start and I wonder if the computer is not right for my car. Also, does anyone know the stock computer # for my car 86 berlinetta, auto, 305 rochester quadrajet computer controlled carb? I got this car with this computer and it wasn't running when i got it but i got it cheap with the intention of fixing it but i can't figure out why it won't start. Thanks for any help.
Old May 8, 2006 | 08:17 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
did you try to check codes?
https://www.thirdgen.org/forums/elec...ght-after.html
fyi, moderator, checking codes maybe should be a STICKY.
Old May 8, 2006 | 05:00 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
yes, it only gives code 12
Old May 9, 2006 | 11:43 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Originally Posted by berlincam86
I have a computer from a 86 monte carlo (it was writtin in black marker on the computer)#1227169 in my 86 camaro is this going to be a problem? .
If the 86 Monte Carlo had a V8 with a carb from the factory then the computer would probably work.
Old May 9, 2006 | 08:54 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
I looked the computer up in partsamerica.com and it's the same number as my camaro lists for a repacement so yea it should work I probly should have done that before I made this thread. I just hope I didn't burn it out somehow.
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
