Car Wont Start
Old May 9, 2006 | 06:55 PM
h1-vltg's Avatar
Car: 91 Camaro Z28
Engine: LS3
Transmission: 6 Speed
Axle/Gears: 3.71
Car Wont Start
Saturday morning I went and had the rear tires replaced, came home and parked the car. Monday morning I go to start her up and nothing... Battery shows 11.9 Volts, and I even tried to jump her with my wife's car.
I have a bad feeling it has to do with the computer, but I don't know how to check that. The car does nothing, I don't hear the starter clicking or anything. Shows all the symptoms of a dead battery, with out the dead battery.
Any thoughts??
Thanks in advance.
Old May 9, 2006 | 07:00 PM
iroctj's Avatar
Car: 86 IROC-Z
Engine: 385 TPI
Transmission: 700-R4
Axle/Gears: 9Bolt 345'S
a fresh or fully charged batt. should show 12.4v and no less than 11v under a load. ck your voltage under a load. a dead cell can show decent voltage but drop to 8v or less under a load. this is prob. your case.
Old May 9, 2006 | 07:53 PM
h1-vltg's Avatar
Car: 91 Camaro Z28
Engine: LS3
Axle/Gears: 3.71
Just tried it, I charged the battery and under load it was showing 12.9 Volts.
Old May 12, 2006 | 08:52 AM
iroctj's Avatar
Car: 86 IROC-Z
Engine: 385 TPI
do the lights radio or anything else work? make sure batt has good connection at the posts/ground on block&body/and at the starter. check your fusible links as well. good luck
Old May 13, 2006 | 06:49 AM
89RS&98Z28's Avatar
Car: 1989RS////1998Z28
Engine: 305////350LS1
Transmission: 700R4////4L60E
Do you have vats system? Pellet in the key...
Old May 13, 2006 | 11:37 PM
sms89gta's Avatar
Car: 89 trans am gta
Engine: tpi 350
Transmission: auto overdrive
Axle/Gears: ?
dont feel bad, ignition moduls.
i have replaced 5 ign modules now, spent waY 2 much money, and is about to give up on my 89 gta. any ideas why it shorts out my modules?
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
