Pop-Up Headlight problem
Old May 15, 2006 | 11:53 AM
StevesBird89's Avatar
I just bought this '89 Formula....Great shape for $2000. Mechanically the only thing wrong are the headlights. They will go up but won't go down without getting under the hood. I was told that there are fuses in line with those...True? And where abouts should I look for these fuses? Thanks.....
Old May 15, 2006 | 12:49 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
well i have an 84 bird which has a relay near the battery mounted on the fender, looks like a box shape and is black and has a wire plugging into it. hope that helps any.
Old May 15, 2006 | 04:08 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
89 Firebird has a different headlight system than the prior 1982-86. On the 1987-92, the weak-link is the headlight motors, or to be more specific, what is inside the large gear. These two-wire motors have OEM gel bushings that crumble to a spoonfull of chunks. At that time the gear will just freewheel on the 3-lobe cam that is on the shaft which raises and lower the headlight bucket. I make a couple of kits to repair this problem (TDS 207280 & 209280). Once you've replaced the bushings, the next thing to fail are the headlight control modules. You can pick up a used one at a Pick-a-Part yard. Be aware that the 1987-89 Firebird used a different one than the 1990-2002. They both look the same (a square black plastic housing with the word GUIDE molded on the cover) and slip into a bracket on the firewall between the brake master booster and the windshield wiper motor.
The older three-wire motors can easily be spotted by their larger diameter **** to manually raise and lower.
Lon
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
