Survey says: headlight switch or relay problem?
Old May 15, 2006 | 02:09 PM
StealthElephant's Avatar
Car: 87' Iroc
Everything works except my headlights, hi and low. Interior lights, instrument panel backlight etc etc all work fine. My hi-beam indicator light in my dash lights up when I try and turn my headlights on. Is it definately the headlight switch or could it be the relay? Not looking forward to taking apart my instrument cluster to pull that stupid switch.
Old May 15, 2006 | 02:12 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
sounds like a relay
Old May 15, 2006 | 04:13 PM
Car: 87' Iroc
I was hoping so, since I didn't think the hi-beam indicator would stay dimly lit if it was a switch problem.
Headlight relay.....passenger side of engine compartment?
Old May 16, 2006 | 04:27 PM
Car: 87' Iroc
Well my problem is definately the relay, you can hear/feel it click but the headlights don't come on. Bosch #25525638
The AC Delco equivalent looks to have a different prong configuration then the one I pulled when I looked it up on their site.
Anyone know the AC delco part number for 87 TPI camaro headlight relay? pep boys was less than helpful as usual. The guy had 2 different relays listed, neither of which he had in stock (3-5 day special order) and you can't return special orders, so with my luck he'd order me the wrong one which wouldn't work and I can't return.
So I got a relay from autozone: Hella #25526984
exact same prong configuration, same exact number on each prong. No go.
My old relay is clicking when I pull the headlight **** out, but nothing is happening. The hi-beam indicator just dimly stays lit. The new relay clicks as well, but no headlights. Any ideas what the problem could be?
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
The_Phoenix
Feb 4, 2016 07:10 AM
tnrednneck
Aug 13, 2015 08:57 AM
