E-brake light stays on
Old May 16, 2006 | 05:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I semi restored the car over the winter, so i'm working out all the bugs now...
E-brake will only pull up, say 6 clicks, and holds the car. Car will roll backwards on a slight hill (my driveway) when e-brake is released, so I think it's adjusted right.
What controls my e-brake light? perhaps I missed a ground under my center console? Is it a wire directly on my e-brake pivot area? I think I remember a wire being connected to that...
Old May 16, 2006 | 06:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's a switch on the brake lever inside the console.
The brake light is also controlled by the switch in the prop valve.
Old May 16, 2006 | 06:40 PM
km7152's Avatar
Car: 1991 Camaro Rs
3 things control your brake light. Fluid level in the master cylinder, pressure in the lines, and yes the e-brake. If the connector is unplugged, the light will stay off regaurdless of e-brake position. If its happened over winter, check your fluid. I know it sounds stupid, but hey. If your pedal feels fine, it probably wont be this but there may be air in the lines or a brake line leak. Or maybe something is tricking the sensor, located at the base of the handle under the console, that the ebrakes up. All simple stuff, but easily overlooked
Old May 17, 2006 | 09:36 AM
Sonix's Avatar
Car: 1982 Trans-Am
my pedal is very squishy, i'm going to bleed the brakes tonight I think. My fluid level is ok though. After I bleed it, i'll see if it stays on, then worry about removing the console to check that wire....
Bubbajones_ya
Aug 28, 2015 02:17 AM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
