'82 Functional Scoop - W/O Crossfire System
Old May 17, 2006 | 10:17 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
TGO Guys,
I've been rackin' by brains trying to figure out a way to make the functional scoop of my son's '82 Z-28 work without the original CrossFire. The solenoid works and the doors can be made to function with battery voltage. The original crossfire (and the entire crossfire engine wiring harness & computer are gone). The current wiring harness and computer are from an '86 LG4. The car is completely computer controlled with a Rochester E4ME and and all the appropriate pollution connections installed and functional (i.e. TPS, MCS, O2 Sensor, MAP, Baro, Knock, Etc.)
I thought there might be some way to "PIGGY-BACK" the signal from the TPS (Throttle Position Sensor) and convert that to higher voltage(s) to make the Hood Doors functional. That would allow partial to full opening as voltage from the TPS increased upward from .48v at idle? I have absolutely no idea how the original system functioned, although I assume there was an Output signal from the ECM that provided voltage/signal to the Solenoid.
I know it may seem a little stupid but my son thinks this would be really really cool and I want to make it work for him. I kinda agree it would be pretty cool even though it won't really be doing anything but letting water into the engine compartment
Anybody made this work? Any ideas? Is there any signal from the '86 ECM that could be used to operate the Scoops. My basic electrical ability is sound, but I have little advanced abilities...
Thanks a bunch in advance....
Kurt
EDIT: Spelling
Old May 18, 2006 | 09:10 AM
mrbunker's Avatar
I have an 82 with crossfire. The signal comes from the ECM to open the doors at WOT (wide open throttle). I don't believe piggy backing the TPS will work unless you could find some type of relay that would operate when you reach a specific voltage. You could place a microswitch in a location that would operate when you hit WOT.
Old May 18, 2006 | 09:34 AM
TheWesman's Avatar
I've thought about doing the same if I can ever find a crossfire hood. I would like to fab up a slick looking custom/factory looking air cleaner to actually make it functional. Sort of like the old school ram air scoops.
I see 2 probable solutions.
1) Mount a switch to at the throttle pedal, like the kind used on say a nitro switch, clutch pedal or brake. Then adjust to suit.
2) Mount up a micro switch using a piece of custom bent sheet metal near the carb linkage that kicks on at WOT. Link sort of like a few nitro setups I've seen. I would also install a second arm/disarm switch in series, and mount it in the cab to turn it off on rainy days.
Depending on the amount current your switch can handle you may or may not have to use a relay based on the current draw of the solenoid.
I wouldn't use an existing throttle position sensor to do double duty by wiring it in parallel. Way more difficult in labor/parts/design to do it this way because a high impedence circuit will have to be build if you go that way.
TheWesman
Old May 23, 2006 | 10:38 AM
Car: 1982 - Z28
New Idea.....Need a bit od Advanced Electical Knowledge....
TGO Guys,
Here's a new idea. Although not perfect it's better than nothing.
We are using a TH-700R4 Tranny (OD). Normally, we drive everywhere in OD. However, on ocassion we want a little better take-off and want to hold the 700 out of OD.
What wire is available that we can use to RELAY a signal to open the Scoops when the tranny is in "D". I know there are several wires at the Shifter Mechanism. Obviously, there is a neutral & park indicator and a reverse lights enable line. Is there anything in the shifter mechanism area that I could "Tap" to open the flaps when in "D"? could one of the wires (4?) that connects to the top of the T700 tranny be "Tapped"??
This wouldn't be the perfect set-up but I could easily wire up a relay if I have a source wire to closed a Normally open contactor.
OTHER INFO:
1986 LG4 Wiring Harness COMPLETE installed in this 1982 Z-28.
Any ideas......
Respectfully,
Kurt
Old May 23, 2006 | 10:50 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Hello Kurt,
Wesman has probably the better idea.The TH400 used a micro switch to activate a solenoid for full throttle down shifts.The switch was located on the gas pedal assembly.Something similar to this or a NOS application would be better than trying to tax the TPS.
Mrbunker is correct the ECM controls the solenoid relay using the TPS as a reference.And this only happens when the car is at mormal operating temps and in closed loop.It's also interesting that the ECM doesn't allow the door solenoid to operate when the trans is in park.
Old May 23, 2006 | 11:10 AM
Car: 1982 - Z28
Coolram,
Yea. I've kinda given up on the TPS idea. The Emissions and all the other factory stuff seems to be working perfectly. All I need to do is have a functional scoop and a lousy running carb/engine...........
However, I really don't want to add anything to the Throttle Linkage that could become lodged in the assembly or otherwise cause a failure (i.e. Jam in WOT ) Therefore, attaching something the Carb is not a option I want to pursue.
Thanks,
Kurt
Old May 23, 2006 | 11:31 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
I did this using a factory GM vacuum switch. No vacuum=open flaps. The only downside is when you key the car on the flaps open up. A micro switch from a nitrous kit as TheWesman posted would work just as well, and not open them when keyed on. There is nothing for it to get wedged on, it would sit under the secondary linkage and only be triggered when the linkage arm rotated down on it (ran one of those on another car for different reasons). I wouldn't worry about them opening in the rain either, it shouldn't be floored then anyways.
Old May 23, 2006 | 12:07 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
what air cleaner arrangement have you got to use the air from the hood? CFI air cleaner doesn't fit a carb very well, i wouldn't think.
Old May 23, 2006 | 12:58 PM
Car: 1982 - Z28
Phess11,
Currently....NONE. It's a looks kinda thing at the moment. However, we (my Son and I) want to grab a spare air cleaner cap from the J.yard and cut a oval opening in the rear (behind the filter) it will line-up very well with the backside of the CFI mechanism. We will add a drain to the base of the Air Cleaner assy to eliminate any water that enters.
Sincerely,
Kurt
Old May 23, 2006 | 09:44 PM
coolram62's Avatar
Engine: LU5 305 CFI
Hello Kurt,
On the setup I'm speaking of for the TH400 the switch is mounted in the car above the gas pedal(I wish I had a digital camera I could take some pictures of the setup on my '73 CST).At WOT the gas pedal arm depresses the switch which activates the solenoid in the trans to downshift(B&M,Painless,Summit or JEGS probably carrys a prefab setup you could adapt).If you know someone that has a car or pickup with a factory TH400 look at how it's setup.You could do something similar using a switch to activate a relay to control the hood solenoid.The factory relay is the same as the relay for the fuel pump.
On the opening to mate with the hood were you thinking of something like the '70-'72 Buick GS used to mate the air cleaner to the hood?Only in reverse or would there be enough room?The second picture is the factory style kickdown switch.
Attached Thumbnails '82 Functional Scoop - W/O Crossfire System-marks71gsx-enginebay.jpg   '82 Functional Scoop - W/O Crossfire System-400switch.jpg
Old May 28, 2006 | 10:33 PM
Car: 1982 - Z28
Here's what I came up with.....
TGO Guys,
I definately did not want anything in a location that could cause binding. I also needed a switch that was not a momentary contact (i.e. NOS Switches) and the switch had to be able to handle continuous 12volt for extended periods of time.
I found this OMRON switch at work, and although it's not exactly perfect, it works well. I milled a semi-attractive little "Shelf" for the switch and welded it to the A/C support bracket. The switch wheel is actually pointed the wrong direction (see photo) but I cut the wheel off another one and it had much more resistance. Power is provided by Accessory (only works w/key on) and there is a switch inside to disable the function in rainy weather. When the car reaches about 1500 rpm the flaps come open (100%). That's not exactly what I was after, but it works.
I purchased another Air Cleaner Top (retained the old one) and cut a couple slits in the rear with a zip-wheel. I tried to slightly MIMIC the look of the hood with a 1" piece in the middle. I retained the bends in the cap to maintain the rigidity and the 1" piece probably helps that also. The flap holes do NOT exactly line up with the air cleaner holes but air can get under the hood and be ingested through the air filter and into the carb when the flappers are open. [IMPO] Sucking engine compartment air into the carb is not the best choice. I don't feel this modification will allow much (if any) hot engine compartment gas to be ingested when the flappers are closed. I may add a "Seal" to the hood in the future. The carb should be getting quite good flow from the dual snorkel set-up as it is...... This set-up might be perfect for a single snorkel......
Tomorrow, (or whenever) i'll weld a small drain fitting into the bottom rear of the air cleaner and attach a small length of hose. To allow any water to be discarded down the rear of the engine over top the tranny.
It's not perfect and it may get a little refinement but this is my "Solution" to my son's request for funtional scoops.......
It does look pretty cool!
Any Thoughts?
Sincerely,
Kurt
Attached Thumbnails '82 Functional Scoop - W/O Crossfire System-z28_flapswitch_tgo.jpg   '82 Functional Scoop - W/O Crossfire System-z28_flapcleancover_tgo1.jpg   '82 Functional Scoop - W/O Crossfire System-z28_flapcleancover_tgo2.jpg
Old May 29, 2006 | 08:45 AM
coolram62's Avatar
Engine: LU5 305 CFI
Hello Kurt,
As i stated in your history thread this turned out great.Maybe fabricate an airbox attached to the air cleaner lid to mate with the air door assembly.The drain is a good idea as you will get water,as you probably already know,on top of the motor when it rain hard or even when you wash her.
Old May 29, 2006 | 02:52 PM
Lo-tec's Avatar
Old Feb 26, 2022 | 10:27 PM
Highlandlad's Avatar
Car: 1982 Z28 Indy Pace Car
Engine: 88 305 HO
Transmission: TH350
Re: Here's what I came up with.....
Originally Posted by kboehringer
TGO Guys,
Any Thoughts?
Sincerely,
Kurt
Hi Guys, I have an 82 Indy Pace car which now has an 88 305 HO motor fitted & 650 Holley carb. I have just got hold of a factory flapper hood & have been given a crossfire air cleaner body which I am keen to adapt to fit on the carb but have the flaps functional. My main aim is to keep some kind of original look under the hood. I’m playing with the idea of operating the flaps using either vacuum or a small pneumatic ram to replace the coil. I will keep you up to date on my exploits.
Old Mar 9, 2022 | 11:28 AM
82-T/A [Work]'s Avatar
Re: '82 Functional Scoop - W/O Crossfire System
I know I've not been on here in a decade, but ran across this. I have literally like 5 sets of crossfire / cowl induction complete sets in the attic of my rental house in Fort Lauderdale, hahah... but I'm a long ways away, so there they will stay for probably another 10-15 years.
Anyway, it's been a REALLY long time since I had a 3rd gen (1982)... and when I was in my early 20s... all the 3rd gens were showing up in the local junkyard... CFIs (LU5?), L69s, whatever... so I saved as much as I could. But I have several large air cleaners that had a mounting pad in the corner where the air box assembly from the cowl induction hood would meet. The air cleaner was a standard size, so literally all you had to do is find another air cleaner base that matched. Also, if I'm not mistaken... the 1984 model year for both Camaro and Trans Am had the higher output 4-bbl carbureted engine... which I THINK was the L69, and you could actually get that entire setup.
I also have an OEM 1984 Camaro fiberglass hood that had the hood vents which actually opened and closed. I brought that home on the roof of a Fiero and put that in storage as well. I was so ******* back then, it was great.
Anyway, all the parts exist, you just need to find them. But this has been done before, and it does make a difference.
You have a couple of options too. You could also install a switch on the floor below the gas pedal that it could interact with. There was a a transmission called the "Switch Pitch" back in the day that allowed for different stall speeds depending on whether you were flooring it, or just cruising around. It was available in the Th325 and Th425, and for a short period of time, the Th-350 and some other longitidunal transmission (memory escapes me). Anyway, in the factory, they mounted the controller switch under the gas pedal.
Finally, the pedal assembly has a lot of slots and holes on it for you to attach various things like the cruise disable switch, etc. You could easily wire something up like that which would "engage" when the pedal is pushed to a certain distance.
Finally, you could also have a "performance" button somewhere that could do a few things... like:
1 - Open the cowl
2 - Engage exhaust cutouts
3 - Engage a solenoid for posi-traction if you install such a mod in your rear differential (they sell kinds that aren't just limited slip, but an actual locker).
Just some cool thoughts.
I'd really like to get another 3rd gen one day. I have so much crap. I even have a bunch of the super crazy center consoles for T-Top cars that goes front to back, or the "Performance Sound" option with the pillar speakers, amp, wiring, and control **** / dash trim... so much cool stuff.
Old Mar 9, 2022 | 12:15 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Relay actuated by a manifold vacuum Hobbs switch.
KDMatt
Jul 13, 2018 04:45 PM
BOTTLEDZ28
Dec 10, 2007 06:19 PM
mdricken
Apr 27, 2005 02:07 AM
