What does this light mean?
Old May 21, 2006 | 09:36 PM
Racing21's Avatar
Car: 1989 Firebird GTA & 2004 Silverado
Engine: 5.7 TPI Fuel Injection
some reason my 92 camaro (Just bought it) has the infl rest light on and it stays on but some times it will go out just for a few min...what does that light mean??i just want the dam thing to shut off so i dont see it on every time i drive...Thanks!
Old May 21, 2006 | 09:46 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you have some problems with the air bag, if your in a wreck the air bag won't deploy.
there is a way you can pull the codes for the air bag system, a search my turn it up.
Old May 21, 2006 | 09:50 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
most likely air bag wiring has a frail or short inside the steering wheel or collumn has the car even been / attemped to be stolen where the collumn has been damaged? but if u service the air bag make sure u disable the battery for about 30 mins to avoid accidntal deployment also check the impact sensor for a loose connection it is exposed to the weather in all it may have some corrosion but most likely u have a bad wire
Old May 21, 2006 | 09:52 PM
Racing21's Avatar
Thank You very much!I just needed to kno the wheel is kinda off set (doesnt line up whe the wheel is straight) but the cars never been into a crash might be a new steering wheel?Idk...i was just hoping its not a really bad thing cuz in a week or so i was just going to change out the steering wheel to a aftermarket one liek the GT ones or ect but anyways....thank you!
i think it might be a wire problem but im going to change it out to the different steering wheel soon but get the stuff turned off before i do it all but i think some one tryed to break into it before but then the consel was fixed....but im not positive if it was messed with...
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
