Melted Connector
Old May 22, 2006 | 11:18 PM
Kwiksilverz28's Avatar
Melted Connector
What is this connector, and why is it melted???
Old May 23, 2006 | 05:31 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I believe that is one of your main power (starter) circiuts. I had a similar problem with my connector and the car would not start because the terminal was corroded. Check you fuse box and see which circiuts are not getting power and that will let you trace it back to that connector.
Old May 23, 2006 | 05:19 PM
That is the issue. Everything is getting power.
Old May 23, 2006 | 08:51 PM
1981LT1's Avatar
Engine: LT1; LT1
Is it just the plastic that is melted or is the entire connector fried?
Old May 24, 2006 | 05:51 AM
No, just the platic. You gave me an idea if no one knows what it is. I will unhook it and see what fails.
Old May 24, 2006 | 06:25 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I want to say that has to do with the heater blower motor but I'm not 100% sure.
Old May 25, 2006 | 06:55 PM
tagta189's Avatar
I have the same connector fried exactly the same way on my car,someone has done a bypass on it though so I am not sure either where it went.
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
wstephan96
Sep 25, 2015 04:28 PM
