91 camaro, charging/no charge
Old May 29, 2006 | 01:57 PM
Niedorf's Avatar
Hello everybody I'm new here but I have a question.
I have a 91 Camaro 1LE Z-28,
The car has Full MSD ignition, underdrive pulley, Autostart, alarm, aftermarket fuel pump. This is the way I bought the car, the last owner said it needed a batt, and alt.
I replaced those and went threw 3 alts, thinking they were the problem.
The car charges at about 11volts, small variation with rev.
if you turn the A/c on it dropps after 5 sec to about 8volts.
if you turn the a/c off it goes to about 10volts.
turn the headlights on it goes to about 14 volts.
with all this the tach bounces alot like a loose connection
This is the wierdest thing i've ever seen, and help?
Old May 29, 2006 | 02:58 PM
precise86's Avatar
Car: 92 RS 25th Anniv
Engine: 305, V8, 5.0
Transmission: auto aka 700R4
Axle/Gears: 3.73 rwd
try checking ur fuses, then ur ground connection. lastly to check ur alternator if u don't have a volt meter have the car running, disconnect the negative ground wire from ur battery...if it cuts off then ur alt. isn't charging ur battery. keep me posted.
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
