Fun with electric Fans....
Old Jun 3, 2006 | 09:13 PM
LiquidSnake's Avatar
Car: 1989 Camaro RS
Engine: L03 V8 305cid
Transmission: Borg Warner T-5
Ok so I bought a new Fan relay since it seemed like mine was bad...I installed it and to my liking the fan worked w/o the AC being on...so I shut it down to go inside and the fan stayed on for about five minutes until I unplugged the relay......I plugged the relay back in and the fan didnt come one so I started it back up and nothing, the fan is back to not running w/o the AC being on...any ideas?
Old Jun 4, 2006 | 06:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Bad thermal switch (located, IIRC, in the pass side head)? This site has a wealth of info. You might try a .
JamesC
Old Jun 4, 2006 | 09:10 AM
xandersdad's Avatar
Car: Now Camaorless
My 86 IROC was having a similar problem, I replaced fan motor, relay then the sensor in the passenger head and it worked. I also had a bad plug by the heater box that was burnt to a crisp and getting a bad connection due to the PO twisting the wires from the relay together so the fan would run constantly. I couldn't find the right plug so 4 splice connectors worked good as well. then my fan worked like it supposed to.
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
92projectcamaro
Sep 29, 2015 07:07 PM
lanceflame44
Sep 25, 2015 12:28 PM
