CAR WONT START need help ASAP
Old Jun 4, 2006 | 06:01 PM
sting's Avatar
Car: '87 TransAM
Axle/Gears: 10 bolt 3.23
The car just turned off while driving.
Battery is good, the parking lights come on (no fog or headlights) and the interior dome lights come on. nothing else. checked the under the dash fuses.
305 TPI '87
need help ASAP this is my daily driver
Old Jun 4, 2006 | 11:05 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Is the 'check engine' (or SES) light comming on with the ignition on ?
Have you tried to pull any codes ?
Does it crank but not start ?
If it's on, the ECM fuse is fine. If not, check the fuse in the weatherpac right off the pos. battery cable .
If you're lucky it threw a code.
If it's cranking but no spark, I have the ign module in the dist. checked/changed. They have been known to die at a moments notice (well, at least mine have anyways).
Just a few guesses.
Old Jun 5, 2006 | 07:14 AM
sting's Avatar
Car: '87 TransAM
Just a few guesses.
well, here's what happened, we discovered a loose wire, one of the 3 red ones going into the starter with fuseable links on them. we fixed it, while i was down there noticed i think its a fan switch was unplugged (fan hasnt been working). so when i hit accessories and everything came on again i heard a buzzing noise then a pop and smoke from wires above the fuse box, not sure if plugging in the 'fan switch' did it or from putting the starter wire back
Old Jun 8, 2006 | 08:52 PM
sting's Avatar
Car: '87 TransAM
here's a rather upsetting update.
car ran fine for 2 days. today coming home from work, car turns off, same as before. saw a little more smoke come from above the fuse box at the same time. get it towed back to the house. no fuses in the fuse box burned. however, the fuse we put in the newly wired fuseable link blew, we put a 30 in there.
what could this be?
anyone know where all three fuseable links off the start go to? and which one of those would cause the car to not start? the only power i get anything from is interior dome lights, parking lights.
also, the plastic part of the connector to the fan switch plug broke, so we left the connector hanging there, could the metal part of it touching against the chassis have caused a problem?
Old Jun 10, 2006 | 01:11 PM
Trans Am Man's Avatar
Car: 86 Trans Am
Engine: 305 with edlerbrock carb
Transmission: 4 speed auto
Axle/Gears: not sure yet!
Check for a loose conection at a junction on the positive side. Similar thing happened to our dump truck, from the road vibrations the nut at the junction backed off and caused the truck to shut off at random times with no power at all.
Old Jun 10, 2006 | 06:20 PM
sting's Avatar
Car: '87 TransAM
We seemed to have fixed her. Required a 14g fuseable link, then the fuel pump wouldnt run, bad fuse (by battery). Also found a few wires in the harness above the fuse box who had melted, and two actually fused together, one of which being a larger orange one, probably causing half the problems. She ran today with no problems.
BlueIroc-Z
Jun 9, 2019 03:22 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Wade787b
Sep 29, 2015 01:15 PM
L98GTA87
Aug 5, 2015 11:02 PM
