failed headlight motors
Old Jun 5, 2006 | 10:13 AM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
Transmission: 700R4 Overdrive
One day last week had alot of heavy rain in houston. i went through a puddle of water. The next morning i turn on my lights, the cluster lights blew out, also the tail and side markers, and the headlint motor hesatated in raising the lights. they were on but would not let down. I replaced the 20a fuse and everything was fine till last night. now they wont raise ,but will close with the switch once raised manually. I put a new isolation relay in and the same thing happend. then i moved the relay to the other two for the motors and nothing. what else can i check.I also pulled the interior switch and replaced with a salvage piece and that one won't raise or let them down all it will do is turn the lights on to allow me to spin them up manually.
Old Jun 7, 2006 | 10:17 AM
Vader's Avatar
Are the tail lights working? Instrument cluster lamps?
Old Jun 7, 2006 | 03:19 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
headlights
the taillights and the instrument lights wern't working until i replace the 20 amp fuse. Now the headlight doors won't work going up. but they will going down.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
LittleFranks
Sep 17, 2015 12:22 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
stalkier
Aug 13, 2015 12:59 PM
