88' Firebird Formula lighting problem
Old Jun 7, 2006 | 10:07 PM
tom858's Avatar
Hi everyone, I'm new to the boards, I'm having a problem with my lights. Heres the scenario: My headlights turn on, but they only move up and not down when switched off. The turn signals, brake lights, and interior lights all work. However, the tail lights, dash lighting, and front signal lamps do not come on with the headlight switch like they should. When I hit the switch, only the headlights turn on.
Ive already checked out\replaced the following
Headlight Motors,
Headlight relay\control module
Headlight switch
Fuses (TAIL&INST)
The front signal lamps come on with the hazard switch and turn signal switch, but not with the headlight switch. The dash lighting illuminates when the hazard button is on, but will not turn on with the headlight switch either.
I'm really stumped at the moment, any assistance would be greatly appreciated.
Old Jun 10, 2006 | 10:10 AM
Vader's Avatar
Check the headlight switch itself:
And the I/P dimmer control module under the dash:
Old Jun 22, 2006 | 09:41 PM
tom858's Avatar
It was the IP dimmer module, problem solved.
Thanks for the help!
Old Jul 7, 2006 | 08:21 PM
budweiserbeauty's Avatar
Car: 1988 Formula
Engine: 5.0
im having the exact problem...what is an IP dimmer module an what does IP stand for?
does anyone have a picture of it or where can I find it?
Old Aug 29, 2006 | 07:06 PM
pheonixthree's Avatar
instrument Panel
xkingcodex
Feb 12, 2020 07:43 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
zeitghaist
Aug 18, 2015 07:33 AM
Omega
Aug 10, 2015 12:46 PM
