Fuel Pump Voltage Q's
Old Jun 12, 2006 | 03:33 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
When I start my car up it runs fine. As soon as it gets to full temp, it cuts out under light throttle. If I put my foot in it, it will run smooth for while but gets worse eventually.
I want to check the voltage going to the pump while the car is driving (under load). What connector could I splice into? Where is the pump grounded?
Could it be the FP relay?
When I changed the alternator the poroblem got a little better so I'm pretty sure it's voltage related. The fuel filter has less than 20K on it.
Any suggestions appreciated, thx.
Ben
Old Jun 12, 2006 | 04:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Have you tried replacing the ignition module in the distributor? Heat makes them worse when they are going bad.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
89GTAOz
May 16, 2020 09:31 AM
92camaroJoe
Aug 13, 2015 06:07 AM
