Speedometer doesn't work
Old Jun 17, 2006 | 12:27 PM
uc360's Avatar
Car: 1988 Firebird Formula 350
Engine: 5.0L TPI v8
Transmission: 5 Speed T-5
Axle/Gears: 3.08
hey guys, i have a 1991 z28 with a 305 auto 700r4 and the speedometer doesn't work everything else works odometer, trip, oil pressure ect...i tried unplugging the vss to see if the SES would come on and it didn't so i thought ok i'll try unplugging something else so i did and the SES didn't come on again, the thing is the car runs fine so i know it's not a faulty computer, im just wondering if you guys could help me out with these two qestions....does the speedometer have a ground wire and if so where is it located?
Old Jun 17, 2006 | 12:42 PM
Zonda Man's Avatar
Car: 1991 Firebird with T-Tops
Engine: L03 - 5.0L 305
I too am having speedometer problems with the same year vehicle , mines a firebird with the 120 MPH speedo. I took apart the cluster and the "screws" that hold in the circuit board. I think its my circuit board thats gone bad.
Old Jun 17, 2006 | 06:42 PM
ShawnPennington's Avatar
Car: 84 z28, 86 firebird, 91 camaro RS
Engine: 84 350,86 V6,91 305
i dunno but check out the connection to the transmisson. unscrew it and check the end of it. i have an 84, Z28 that im swaping the 305 with a 350.. and my cable was bad. so i dunno if there that same but i would check that..
Old Jun 17, 2006 | 11:31 PM
uc360's Avatar
Engine: 5.0L TPI v8
Axle/Gears: 3.08
no there not the same mine is all electronic, and i did check the vss on the tranny, but doesn't the vss also run the trip and odometer?, because both of those work.
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Wade787b
Sep 29, 2015 01:15 PM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
