brake light?
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
brake light?
i have an 89 firebird formula and i have a problem with my brake light, it's always on even with the brake down. do i need to replace a sensor?
where is it? any help with this is greatly appreciated. thanks in advance.
If you are asking about the brake warning lamp on the dash, there are two switches - One for the park brake, and one on the combi valve under the master cylinder. If there is a hydraulic problem and high differential pressure between the front and rear brakes, the switch on the combi valve will close.
so if my rear brakes don't work because the front brakes were done but the system didn't get bled the light will go on?
Excessive pressure differential between the front and rtear braking systems will operate the switch. If you think the problem is there, unplug the wire from the switch and see if the lamp goes off. If so, start investigating the brake hydraulic system.
