Wiring question Injector Fuse 1 & 2
Old Jun 20, 2006 | 06:57 PM
Wolken's Avatar
Car: 89 Firebird Formula / 88 Camaro
Engine: 5.0L TBI / 5.0L TBI
Transmission: Auto / Auto
Axle/Gears: stock
I bought an 89 with some burnt up wiring, namely the wire that goes from the ignition to the coil. Whats left of the wire looks like it was also spliced into the 2 pink wires that feed the injector fuses. Is this how its supposed to be or should that feed come from somewhere else?? Please help I need to get this car running so I can change the head gasket on another car that broke right after i got this one.
Wolken
Old Jun 20, 2006 | 08:39 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
The pink wire to the coil runs through the C100 connector and to the ignition switch. It is pink and a heavier guage wire than most of the others.
Old Jun 21, 2006 | 08:37 AM
Wolken's Avatar
Axle/Gears: stock
wiring
Are the injector fuse leads supposed to splice into that wire? I also found another burnt wire under there last night. I have to trace that one and figure out what the problem with that one is. I looks like there is a pair of red wires that splits into about 5 of them under the dash, is that normal? It seems out of place.
Old Jun 21, 2006 | 11:00 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
GM does do that in their harnesses. It usually looks like the uninsulated parts were squeezed together and heated. Does this make sense?
Old Jun 25, 2006 | 05:02 PM
Wolken's Avatar
Axle/Gears: stock
I got it figured out and running on Friday. Unfortunatly the motor sounds like it is missing quite a few bearings and will need to be replaced but at least the electrical is solid.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
redmaroz
Aug 16, 2015 11:40 PM
