Third Brake Light
Old Jun 20, 2006 | 08:19 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Third Brake Light
Well I cant get my third barke light to light up. I tried it with bulbs that were not blown and it worked for a few minutes, then stopped. I even tried using a different brake light assembly with no luck. What else can I do, is there a fuse for it or something? Thanks for any help guys.
Old Jun 24, 2006 | 09:57 AM
Vader's Avatar
Are the replacement bulbs still good? After all, it DID work briefly...
Old Jun 26, 2006 | 01:09 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
THREE BRAKE LIGHTS, NO WAITING
You have a separate switch at the brake pedal
for that nerd light. It uses the same fuse as the
normal brake lights so if the normal ones light
the fuse is good. Go to your friendly local electronics
store and get a volt / ohm meter. Now you will be
able to test the switch and trace the wires coming
off it and going to the nerd light socket.
Happy Racing!
-If people drove any slower
they’d be going backwards-
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
