hatch pull down question
Old Jun 21, 2006 | 09:15 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
ive read the repair document and am ghoing to order the replacement motor housing from TDS. howver i do not have the money just yet to buy the part.
my question is this: does anyone know a way to ghetto rig the motor housing to the frame so my trunk will continue to shut even if its just for a little while?.
Old Jun 22, 2006 | 06:43 AM
j dezzy's Avatar
Car: 87 TA
You can disconnect the latch portion from the motor, use a screw driver to hold the latch up, shut the hatch with enough force to make it latch then pull the screw driver away at last second. If you pulled the screw driver out of the latch at the right moment then the trunk should have latched. although it will still move up and down slightly it should still be latched. And it won't be very water tight. I had to do this to my girlfriends camaro while I refurbished her hatch pull down motor.
Vintageracer
Jan 10, 2020 05:33 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
madsv1000
Aug 20, 2015 06:45 AM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
