choke light stays on
Old Jun 26, 2006 | 09:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Car info in sidebar. I have converted to non cc carb, have the distributor to match, and a non cc quadrajet, using the choke wire, as normal.
I have retrofitted in a cs144, used the resistor inline with the wire.
So, two days ago, driving spiritedly, just getting to my house, my choke light lights up. So I pop the hood, and sure enough the choke wire had fallen off. It was sitting on my intake manifold. So I pushed it back on, and went in to sleep. Car was off, so didn't know if the light went off or not.
Next day, go out and drive somewhere, choke light is still on.... I checked voltage with the engine off, 12.9V, with engine running, 14.4V or so. Checked with multimeter, verified with gauge in cluster. I'm thinking alternator is running ok.
Wire while touching the choke, with motor running (cold), showed 1V.
Could I have shorted out the choke wiring, and popped the fuse? I would think that would turn off my choke bulb, rather than leave it on...
Any ideas?
-J
Old Jun 26, 2006 | 09:52 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
You don't need it, pull the bulb
Old Jun 27, 2006 | 10:55 AM
Vader's Avatar
Don't pull the bulb. Get a 2" hole saw and 1/2" drill. Hog out the section of the instrument cluster that holds the CHOKE light, and remove it. You'll never have a problem with it again.
If you want to repair it properly (so that it works as intended) consult this:
The CHOKE HEATER / FAN fuse is suspect, since the wire may have grounded. The voltage you are reading there may be bleed through the CHOKE warning lamp filament.
Old Jun 27, 2006 | 11:15 AM
Sonix's Avatar
Car: 1982 Trans-Am
hmm, ok, i'll check my fuses tonight, thanks.
Old Jun 27, 2006 | 07:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
aces, CH fuse was blown.
guess I shoulda checked that... ahem, anyway, thanks.
Old Jul 1, 2006 | 12:39 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
The K.I.S.S principal has struck again (Keep.It.Simple.Stupid) lol I love that principal it solves a lot of thing usually.
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
