ignition or ecm problem
Old Jun 30, 2006 | 05:13 PM
leathalirocz's Avatar
Car: 1988 Irocz
Engine: 355 Stealthram
Transmission: 5speed
Axle/Gears: Stock 10bolt 3.73 posi
Well i thought i had it figured out but... wrong answer. Well here is whats going on, i just swapped out my TPI for a HSR on my 88 iroc with the comp 08-306-8 roller cam 30lbs SVO injectors, Brodix heads, MSD digital 6+ box, MSD coil, factory distributor with a pickup & mod only about 6 mouths old {ran fine with my TPI} Autometer tach and a custom eprom by LSRacing. With the car running at 1000rpm's and a scanner hooked up the computer is saying its running at 2500-2700rpm's, and with my tach at 2000rpm's the computor reads 5850rpm's. I checked the 4 wires running back to the ECM from the 4 pin on the mod and they are all ok and in the right spots, all the programing and sensors are checking good, jamy from LSRacing even got my BLM;s at 128 with out having the car so i dont see the problem in the new prom. A friend owns a dyno shop and told me to find out what wave length the signal from from the distributor to the ecm is Square or sign. He was wondering if we could take the signal from the tach drive off the MSD and pipe it into the ecm and what wire it is that carries that signal. Any help would be great cuz if i dont figure it out soon i will be converting to carb. I tried a different coil, mod, and running it without the MSD but no change. Thanks Chad.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
