Remote start
Old Jul 1, 2006 | 06:16 PM
puntank4200's Avatar
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
Remote start
Just purchased a commando rs-560 and installed all of the alarm and power lock features. Alarm and power locks work great, but when I installed the remote start feature I get nothing? I installed the wiring for the starter output, two 12v inputs, ignition output 1, there is no ignition output 2, and the heater/acc output. I haven't installed anything for the tach signal, brake switch out door pin triggers. When I press start on the remote nothing happens? Do I need to install the other wires, I was told it should start without installing the other wires yet. I tested the wire from the module to the starter output and when I press the start button I don't see any voltage? Any suggestions? To hook the the tach signal input I need to wire this red and white wire to the coil, but which wire, there are 4 wires coming out of the coil?
PS. I need to wire the alarm to the parking lights. What are the parking lights, where can I tap into them?
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
