SES Light Bulb
Old Jul 3, 2006 | 08:56 PM
smccrillis's Avatar
Car: 87 trans am
Engine: 350 tpi
SES Light Bulb
I'm not sure if this is the right place for this question but here it is.
Has anyone had a problem with the bulb for their SES light? I took apart the dash to check it out because the light wasn't coming on and I found that the plastic that holds the bulb in place is worn down and doesn't hold it tightly. I tried some electrical tape to hold it in place and it worked, until I put everything back together and now it is loose, and flashes whenever I hit a bump in the road. Does anyone have a suggestion as to how to get it to stay tightly connected? Or would I be better off swapping out the whole panel?
At least I was able to check my codes before the light went out again.
Old Jul 5, 2006 | 08:55 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Try replacing the socket with a new one.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
