Too much spark at top of coil
Old Jul 5, 2006 | 06:38 PM
dolphan7's Avatar
I have an 86 Firebird TA that I just swapped 305 to 350. Put in stock dist, but added Accel coil, wires and cap. Problem is that the top of the coil will give you a huge shock when you touch it when the engine is runnig. We added a ground wire from one of the screws to the firewall and it works fine, but this isn't right. Why is this happening?
This is the big distributor with the coil on top of the cap.
Where does the distributor ground to?
Old Jul 5, 2006 | 07:25 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Don't touch it while its on- problem solved. After the coil these things have 30,000- 50,000V, so don't touch it.
Old Jul 5, 2006 | 08:54 PM
JB22's Avatar
yeah when we were timing my new 350 over the weekend, we shut the car to adjust timing. My buddy had gotten zapped real bad on a previous car and woke up on the ground, so we chose to avoid that at all costs...
Old Jul 5, 2006 | 08:55 PM
dolphan7's Avatar
Yeah that is good advise. My mechanic told me that he got shocked. Before this it was arcing but now it runs ok. I wonder how you are supposed to adjust the timing if you can't touch it when running?
Old Jul 5, 2006 | 08:57 PM
JB22's Avatar
Turn it off, adjust, and start it back up.
Thats what we did.
On a separate note, you having issues idling high after your swap?
I have yet to reset the IAC and TPS, but Im idling around 1000-1200 with the EST plugged in. I idle around 750-800 with the EST Disconnected.
Old Jul 5, 2006 | 09:16 PM
dolphan7's Avatar
Thats what we did.
I don't know what we are idling at. The car is at my mechanics shop. Still running open headers so I need to get that finished first. Then I can drive it around. I have heard it run and it sounds like it runs smooth and well under 1000.
Old Jul 5, 2006 | 09:22 PM
JB22's Avatar
cool, thanks for the info.
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
