Voltmeter Gauge out. Maybe the regulator?
Old Jul 6, 2006 | 03:32 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
My Volt gauge is out, meaning its constantly zero. I was Thinking it has to be the internal Voltage Regulator inside the alternator. That make sense at all.
Old Jul 6, 2006 | 07:29 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
TRYING TO GAUGE THE PROBLEM
NO.
We’re gonna assume the rest of
the car is OK since you didn’t mention
anything. Now, , , , , , , your voltmeter
is defective/disconnected from the circuit.
Happy Racing !
- If people drove any slower
they’d be going backwards -
Old Jun 8, 2010 | 03:15 PM
Re: TRYING TO GAUGE THE PROBLEM
im going to replace the heater core in a couple days ill check the circuit with a volt meter external display, i heard the resistors can blow when an external grounding of a secondary battery or a failed alternator faliure, i thought it was the differences of the circuitry that blew the circuit the the voltmeter in dash. the Upon checking the diagrams of the two different alternator i came to notice they completely different, but ill find out for sure when i pull the dash. (83' alt compared to 85'
TrevinE
Sep 14, 2015 03:20 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Glowsock
Sep 6, 2015 06:40 AM
machinist21
Sep 5, 2015 03:03 PM
