ignition switch replacement
Old Jul 12, 2006 | 05:46 AM
nathanielehlert's Avatar
Car: 1986 Camaro Z28
Engine: 305 TPI i might be a 350
Axle/Gears: Stock
i am in the process of changing my igniton switch and i cant figure out how to get the cable thats connected to out i am not sure what its for but it stoping me the car is an 86 camaro z28
Old Jul 12, 2006 | 04:06 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Are you talking about the switch located near the brake/gas pedal on top of the steering column or the cylinder that the key fits into?
Old Jul 12, 2006 | 04:38 PM
snowman_az's Avatar
Car: 1982 Z28
Engine: 355 V-8
Transmission: Super T-10
Sounds like he's talking about the actual ignition/key switch, since the wires run through the column.
Just guessing, though!
In the past, I cut my existing wires and then I used a wire coat hangar and fished them through the collar on the steering column.
Old School!!!
Old Jul 13, 2006 | 02:28 AM
Axle/Gears: Stock
the switch at the bottom of the column
Old Jul 13, 2006 | 09:34 AM
snowman_az's Avatar
Car: 1982 Z28
Engine: 355 V-8
The switch that is on the top of the steering column has 2 seperate plgs attached to it, from the right side. There is a aluminum plate on top that you just need to carefully pry up enough for you to unplug the cables. It will be a lot easier to unplug these cables, with the switch still attached to the column.
Hope this helps.
Old Jul 13, 2006 | 02:51 PM
Axle/Gears: Stock
i changed it last night so thanx
Old Jul 28, 2006 | 08:20 PM
rljohns1's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Cable not wires!!!!!!!!!
He is talking about the cable the is on the back part of the ignition switch. This cable runs to the shifter for automatic transmissions and acts like a neutral safety switch this is why your car will not start unless it is in park or neutral. To remove the cable you have to make sure the switch is in either acc or on position, this will release the tension from the plunger that holds the cable in place; remove the 2 small philips screws, which will free this cable assembly from the ignition switch. Then you will have a closer look at it and there should be a clip that has to be pressed to release the cable from the plastic housing. Most of the time when you get a new ignition switch it will have a new plastic housing already attached. Make sure the new ignition switch is in acc or on position (basically the middle 2 positions), then just put the cable back into the new housing and it will click into place. Finally, put the switch back into off position and put everything back together (last part easier said then done)... Hope this helps the next person that tries to do this on their own.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
