open loop vs closed loop
Old Jul 15, 2006 | 11:01 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
My question is what comes online in closed loop? My car developes a miss or floods the engine the second when it goes into closed. I hooked it to a scanner and no codes or mill light but drove around with it hooked up and it drive fine untill closed loop hits. So I unpluged the oxygen sensors so the car stays in open loop and everything is fine. Is the oxygen sensors the only sensor that comes into play in closed loop?
Any ideas?
Old Jul 18, 2006 | 08:56 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
if it is a fuel injected car then several things come into play in closed loop.
Throttle position sensor
Mass air flow sensor,
Baro sensor
probably more.
should move this to Engine/Tech
Old Jul 18, 2006 | 09:07 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Unplug your knock sensor and see if that helps. If you have a performance exhaust or even a bad knock sensor it will pull timing like crazy.
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
luvofjah
Sep 3, 2015 07:08 PM
