Keep blowing brake light fuse. Need Help!
Old Jul 17, 2006 | 07:17 AM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
Just like it says, I keep blowing the brake light fuse in my 86 IROC. I need a diagram or something for the entire brake light system (including the hatch mounted brake light) .
I'm wondering if it is possible, that since I disconnected the third brake light, and removed the little connector panel from the top of the hatch (that touches the plate on the hatch motor cover) it is causing it to short out.
Old Jul 17, 2006 | 03:04 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
bump...
Old Jul 18, 2006 | 09:20 AM
Vader's Avatar
Does the fuse blow immediately, or only after the brake pedal is depressed?
Old Jul 18, 2006 | 03:47 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
Got it fixed. The fuse was blowing immediatley. Found out it was wired up with the "key in ignition" alarm on the fuse. I pulled the box and the fuse quit blowing.
Ghettobird52
Jul 5, 2024 11:18 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
