Can I interchange trans am dash into a camaro
Old Jul 18, 2006 | 10:30 AM
Camaroman P's Avatar
Car: 1998 Z28
Engine: 350 lt1 sued up
Transmission: 460le
I have a trans am and a Iroc both 87 But I like my Trans am Dash does it bolt up the same to my camaro I have all the wirs becasu I have the whole car I like the VSS and I want to put it in my Iroc someone please help thanks
Old Jul 18, 2006 | 10:58 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Sure. I've done this swap. The main four bolts holding Trans Am dash and Camaro dash in place may differ as in, they may not bolt right up. However, the other sheet metal screw locations are close enough to hold the transplanted dash in place while you fab up the corners. Everything else is pretty straight forward. The center consoles will need to be changed and some of your accessories may wire up a little different or at other locations. Go for the whole harness / dash transplant and the job gets easier. The hardest part of the project will be converting to vss if your Camaro has a speedo cable. To simplify that I would suggest more transplanting of the Trans Am wiring harness and ecm as necessary, just make sure that they are compatible. Good luck!
Old Jul 18, 2006 | 07:59 PM
Car: 1998 Z28
Transmission: 460le
trans am dah swap
Well I am putting the whole engine and tranny in so it should work pretty well thanks alot I will keep you posted if I get stuck
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Vintageracer
Aug 11, 2015 08:13 PM
