Which wire to ground??? Fan relay.
Old Jul 21, 2006 | 02:13 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I have the dual fan set up. I already got the primary fan hooked to a switch so I can controll when it comes on. I tried grounding the green with white stripe wire on the second relay and nothing. I checked the fan by turning the AC and it came on.
I was just wondering if there is another wire I have to ground on that second fans relay???
Old Jul 21, 2006 | 04:42 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Ground the wire that goes to the fan switch.
Old Jul 21, 2006 | 02:09 PM
Which wire would that be???
I don't wanna ground a wrong one since I don't have a wiring diagram!!!
With all due respect, why have I been getting answers like this???
I posted the same question on the cooling board, and all I got was "change your prom" or someone telling me they did it with their prom. Now, I know which type of wire I need to T into, but I don't know which wire that is.
I mean, all I need is the color of the wire and I'll be set.
I don't really think there are any differences between fan relays throughout the years!
So, don't take this as an insult or as a jab, I just wanna know which wire it is, and I seem to be getting answers, but not the one I am looking for.
Thank you.
Old Jul 23, 2006 | 02:26 AM
Anyone???
I've been reading that the gray wire has something to do with grounding the relay, but I don't wanna ground any wires untill I know.
Old Aug 5, 2006 | 02:21 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
On my car it was the green wire.
Kevin
Old Aug 5, 2006 | 02:27 AM
First relay (closest to the driver side) you need to ground the green with white stripe wire.
Second relay (right next to the first one ) you need to ground the grey wire.
THAKS VADER!
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Jae992
Aug 27, 2015 09:07 AM
Bert87
Aug 23, 2015 03:50 PM
